VE SSV ute exhaust rattle at idle.
Glenn Hall
74
St Georges Basin
VE SSV UTE 2010 AFM.
First rattle only happened at idle when cold and reverse was selected, it is an auto. Now the rattle happens even in park or drive. The rattle can also be produced when backing off in low gears in manual selection. First I was told it was the Cat's and then the centre muffler, Exhaust system changed to almost new 2nd hand system that fixed it for about 1 week, now back rattling as before. When the tail pipes are pushed up or down by hand with sufficient force the rattle stops. Maybe rubbers or hangers?
lmoengnr
Donating Member
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
Might need to get it on a hoist and inspect it.
Check all the mounts, and check that none of the heat shields are loose, or touching the exhaust.
Glenn Hall
74
St Georges Basin
Thanks for the reply but this has been carried out 3 times now with a complete exhaust removal and replacement with heat shields checked for clearance and loose fittings.
Voodoo_SV6
58
MY12.5 E3 R8 Manual+MY16 VFII SV6+MY11 VE S2 SV6
You didn't put in an exhaust with bi model mufflers did you? (Even if that's disconnected)
krusing
Melbourne, Bayside
Sounds like the top of the cats concertina fittings, [expansion units at the top of the cats]
Glenn Hall
74
St Georges Basin
No mods to the exhaust ,it is standard, but thanks for your interest. I think it may be hangers or rubbers but that means on the hoist and removal again, nothing was found faulty the first time but it did fix it for about a week.
