All done
Only remove the steering column shroud if you can't get the airbag off, as the shroud is a huge PITA to get back on (I only just found that out! Took a good 15min to get back on)
I tried to leaver out the airbag but couldn't leaver up enough as the screw driver was hitting the shroud, after the shroud was removed, it took 5 seconds per each clip. Easy as.
Remove the strip (all clipped in)
Remove shroud (Clipped in)
Insert flat head screw driver as per first page
Leaver up
Step away from the airbag......
The airbag cables don't have much give in them, so don't pull the airbag away from the wheel too quick, otherwise things will break, these pieces came off the airbag plugs (but the still plug in fine.)
Also, a picture of the T45 bit, just for reference.
All done!
