Ok so i got another "alignment" done yesterday...
Got ripped off again, this time got the before and after readout of the angles, but inspection tells me they have not adjusted if at all...
The angles of camber were apparently right in between specs, only toe in was adjusted according to the read out..
Anyway, for a rough check of camber, i got a straight edge of steel to cross from top - bottom of tyre.. I parked car on level cement.. Checked tyres with bubble level.. The left side was slightly negative camber, the drivers side was negative also but much worse..
As I always thought the camber is far too negative so the figures are obviously false!
For a rough check i believe this is adequate... Ringing them up tomoz and going to ask them to fix and refund bloody hell i just want an honest alignment!..
Having my tyres worn down probably discourages them from doing it properly thinking ill never know.. bloody wheel no change alignments over it!
I got 55,000 out of the Yokohama S drives same story Worn in the center running 38PSI.
Accept for the rear wearing the centre (Tyre pressure??)they did not scrub out on the front or rear.
When i got the tyres changed they did a wheel alignment and told me it was out and they had adjusted.
if it's not broke why fix it? i will be keeping a close eye on the wear.
