ve transmission shift problem
clutch1967
shepparton
04 SS , 06 ve sedan , 79 VB SLE
I hav a 06 ve v6 v-series
I just put in a new auto trans
problem I am having is now it's not changing gears and putting up (shift/timing solenoid,low ) code p0787
any idea's what I am missing or forgot
greenacc
Searching for the billion
VE Berlina
Any wires or plugs you didn't connect?
Skylarking
120
Downunder
Commodore Motorsport
What do you mean buy “new”; do you mean it is an unused new of the shelf auto or a reconditioned auto or a low kilometre used auto?
Did flush the pipes and trans cooler and torque converter? Sure you put trans fluid in it after the install (takes lots of fluid if TC dry).
See the following for common 4L60E auto issues
Oh, and it may be worth also checking this page ;)
clutch1967
shepparton
the trans was out of a running drive wreck shifted fine in it
I used same convertor that was with the box flushed the trans line's had then out of car
But I didn't flush the trans cooler for got that 1
checked all the wiring plugs etc all look good
trans fluid level is good
I cant think anything else
greenacc
VE Berlina
Shifter connected correctly? It's not in neutral is it...
clutch1967
shepparton
shifter is all good
it runs drives in reverse and in drive just wont shift out of 1st gear you up to 100k's (4000revs) and it wont change gears
Utel67
Tasmania
Vs s3 ute
Unplug the big plug on the transmission and test drive, this will put the transmission into limp home mode which will give you 3rd gear starts, if you have this the most likely cause is the shift solenoid A.
VTS5
TechJunkie
Sth.East\Melb
VE OMEGA 3.6L Dual Fuel
Did you engage/slot the converter in to the pump before the installation?
clutch1967
shepparton
ok I will give that a try today
