there was a little grit in the pan nothing to bad tho fluid was a little burnt but seen worseDid you remove the pan on the the transmission, was the fluid burnt ? or was there like a fine sand grit material or metal stuck to the magnet ?.
I will watch that link now thanksHave a read and watch the video in the link.
https://www.google.com/amp/s/www.70...0e-shift-solenoid-symptoms-and-diagnosis/amp/
don't have a tech2 but I do have a audtel scanner it reads most of the codesTech2 which you’d only get on eBay for us amateurs.
You would also be best armed with the factory manual.
ok I will hav a look at that now thanksHave a read and watch the video in the link.
The Tech2 will be able to isolate components and test their functionality.
Code readers can’t do that.
You can find one for around $400. When looking at lost time or even the cost of a couple of trips to a well equipped mechanic, they can pay for them selves quite fast.
