VE tuning rumble
Brunwick, Victoria,
Sportwagon 3.0 International SIDI – and old Chevs.
Hey there!
My 09 VE has recently developed a bit of an engine rumble at idle and low throttle driving speeds. It disappears when I give it some juice.
And this is with the aircon off.
Idle speed is just over 500rpm according to the dash dial – probably 525? (The rumble is gone at about 600rpm.)
Is this the correct idle?
Or might there be something else happening with the tune, or a fouled injector or something?
Running 95.
Advice welcome ... before I take it to a mechanic or (gulp) a Holden workshop.
Brunwick, Victoria,
Just did a freeway drive and can report:
The rumble is somewhat present in top gear with just a little throttle – that's about 1100rpm.
And when I select reverse the rumble is even more noticeable – giving the car quite a shake.
Engine mounts maybe?
Brunwick, Victoria,
My mechanic took a look at it and agreed it was not right – more than just incorrect idle. Suspected engine mounts and tested – load at standstill made the engine rise up visibly ... both in D and R. Swapping out for new next week.
