Ve ute install
Discussion in 'Car Audio' started by Jazzas202, Apr 9, 2015.
  1. Jazzas202
    Jazzas202 New Member
    Australia
    VE Omega Ute
    Need some quick answers for this install as im going to the shop tommorow to discuss.
    I am thinking of getting kicker cs component speakers and a kicker 2 channel amp to run it. Price is $489 which includes fitting.
    Also where do people mount amps in utes??
  2. 'ssv'
    'ssv' Member
    VE SSV MY9.5 M6 UTE
    You say 'also' but only asked one question???
    I have 2 amps and a sound processor mounted on the floor, under the seats.
    just velcro'd to the carpet.
    Never had an issue.
  3. Jazzas202
    Australia
    VE Omega Ute
    sorry mate first question was meant to be is that price reasonable? and thanks that amp under the seat sounds good and takes no room
  4. 'ssv'
    'ssv' Member
    VE SSV MY9.5 M6 UTE
  5. Jazzas202
    Australia
    VE Omega Ute
    Yeah they are the right speakers but its this amp KICKER | DX125.2 Amplifier
    Yeah think they are doing new wires as the is a wiring kit included in the price
  6. jr_
    jr_ Donating Member
    VE II Sportwagon
  7. Jazzas202
    Australia
    VE Omega Ute
    i just looked it says PRODUCT DESCRIPTION
    DXA125.2 2x60-Watt Two-Channel Full-Range Amplifier
    * also the car audio place said it will have plenty of power for the speakers
  8. vongy10
    vongy10 Active Member
    Gunnedah
    CV8 Monaro V2
    Those speakers will only be receiving 30watts because they're 4ohm. Might as well wire them up to the factory unit... I'd get a more powerful amp.
  9. Jazzas202
    Australia
    VE Omega Ute
    which kicker amp should i get? install is Saturday and not sure if im able to change or not
  10. EYY
    EYY Well-Known Member
    VS Statesman
    I prefer amplifiers to have at least an equal rms rating as the speakers they'll be powering. Ideally higher.
    Underpowering a speaker will cause 'clipping' at higher volumes which has a much worse effect than overpowering a speaker. You can always lower the gain on a larger amp too so you won't be overpowering the speakers to the point of damaging them.
    That amp you've got will be considerably better than a headunit, but a properly matched amp will allow the speakers to perform to their full potential. They'll even sound better at lower volumes.
  11. jr_
    jr_ Donating Member
    VE II Sportwagon
    not answer what amp you should get but a quick google search shows Kicker appear to only have three 2 channel amps in their current range:
    (KICKER | Amplifiers)
    - DX125.2 - 2 x 30w at 4ohm
    - KX200.2 - 2 x 50w at 4 ohm
    - IQ500.2 - 2 x 125w at 4 ohm
    you are getting 4ohm speakers that handle 100w, you need as close to that a possible (either higher or lower) to get the most of this.
    nb: the IQ500.2 is going to close closer to double than your current budget...
    have you paid any money / deposit to this store yet?
    does this store sell any other brands besides Kicker?
    did they recommend any other packages?
    maybe see if they're got a good combo in the 50-80w (being both speakers and amp)?
  12. Jazzas202
    Australia
    VE Omega Ute
    i have already paid a deposit of $250. i would like to stick to those speakers and the store said this combo best matched my budget and said the amp is well suited to the speakers so i just agreed assuming he knew best.
  13. EYY
    VS Statesman
    Not the end of the world mate, the amp is really easy to change once all the wiring's there. That's providing that the wiring is adequate for a higher powered amp.
    Make sure they use at least 8 gauge wire for the amp. If they aren't, do what it takes to get your money back from them and find someone else to do the install. From what you've told us already, it doesn't sound like they really know what they're doing.
  14. vongy10
    Gunnedah
    CV8 Monaro V2
    Just get them to switch the amp for a more powerful one. Better than paying for that weak one now then getting another.
  15. Jazzas202
    Australia
    VE Omega Ute
    Yeah they are using 8 gauge wiring kit to do it all so that will be right might just tell them to use a better amp. will this one cut it or should i go 4 channel? KICKER | KX200.2 Amplifier;
  16. vongy10
    Gunnedah
    CV8 Monaro V2
  17. vongy10
    Gunnedah
    CV8 Monaro V2
  18. Jazzas202
    Australia
    VE Omega Ute
    Only talking kicker cause i know they stock them, I will have to ask what else they have
  19. vongy10
    Gunnedah
    CV8 Monaro V2
    Kinda odd that Kicker don't make their speakers support 2ohm.
  20. Jazzas202
    Australia
    VE Omega Ute
    I dont really get this 2ohm 4ohm stuff and how the wattages change but i am messaging my installer and says they have got a few more powerful amps in stock so what wattage and ohm am i specifically after?
