Ve Ute L76 Dod delete, cam and valve train kit, otr intake, exhaust mod
shane_3800
35
places
vr commo
If you're working the heads send them to higgins race heads and get a propper job done. He'll Newen CNC cut the guides then CNC port the heads.
But the stock heads flow enough that porting won't show much gains on a 6l you really need 7l+
With cam I recommend the BTR cams as Brian Tooley is a wizard with engines. He's cams are all gound and made at Comps machine shop.
vr304
Auckland, New Zealand
2007 ssv manual
I see your in NZ mate I’d highly recommend talking to Wayne at protune automotive in manakau he’s a guru with LS stuff, send to him for tuning if your gonna do the mechanical work yourself
LsBeema
45
Newww Zealaaaand
Bmw E36 L98
Thanks guys. So...guy I work with...Phil, owner of this soon to be Monster..had some bad words come to his ears...and decided for me not to port and polish the heads. I will do it on my L98 in my Bmw and see the results. Annnnyway...WHAT A FREAKIN JOB!!!! Stage 2 cam kit from Franklin Cams, Dod and inlet kit from Mace, bush kit for rockers from I dont know, still to price up resonators, fab H pipe, rear muffs and fab tips...flip...exciting!!!
  • Like
Reactions: Lex
LsBeema
45
Newww Zealaaaand
Bmw E36 L98
1st time doing a job like this. Freakin exciting man.!!
07GTS
Australia
VEGTS BUILT BLOWN E85
make sure the timing chain tensioner is ok, can be better to use a early LS2 dog bone type, i have the same as u have and mine broke and i found the tension spring in the sump, u dont get any issues with the dog bone type
LsBeema
45
Newww Zealaaaand
Bmw E36 L98
Thanks homs. Did an inspection
.she looked all sweet. I will source a dog one out though. Thanks man.
