VE V Check Engine help needed
Discussion in 'VE Holden Commodore (2006 - 2013)' started by Cammo6556, Dec 20, 2010.
  1. Cammo6556
    Cammo6556 New Member
    2006 V commodore
    Hey guys.
    A few weeks ago, my check engine light came on. I've noticed a lack in responsiveness and power, slight sputtering on occasion, a slight odour (could be fuel). The light went off when the tank was filled above half the first two times but the power was still a little iffy. Yesterday, an X appeared on the dash and told me to contact the dealer.
    I'm thinking it's just dirty injectors, but could it be anything else? And can anyone recommend the best (and cheapest) way of getting it fixed?
    Thanks heaps
  2. Michelson4301
    Michelson4301 New Member
    Cairns, Australia
    VS Super6 Utility 5 speed
    Buy a cheap obd2 scanner of ebay. May or may not have the correct codes for your vehicle. Failing that, take it to your local mech. Don't believe there is a flash code system in the newer commodores.
  3. Cammo6556
    2006 V commodore
    Thanks mate. Will do. Appreciate the advice
  4. igo
    igo New Member
    VE Calais V Series II
    May be timing chain issue - some MY06 3.6L V6 engines suffered from stretched (or loose) timing chains, or something to do with the fit of the chains to the drive teeth
    It happened to my MY06 Calais at approx 75000k - the 3 chains were replaced. Fault and check engine warning was intermittent at first but became permanent over about 500k - didn't much notice the power drop until it was repaired then the car had a lot more get up and go
    suggest that you get it checked - good luck with it as it isn't a cheap fix unless the General comes to the party as they did with mine
