locoman8434
- Jan 12, 2015
- 8
- 0
- 0
- Age
- 77
- Location
- Australia
- 04 wk statesman
Have done a search on this subject and it all is a bit confusing as it seems there are so many different scenarios.
My mates 07 VE is dripping clear water from under the dash when the air con is on. We have cleaned out the plenum, although there was hardly enough gunk to create a blockage, and that material was dry however we noted two other issues while in there, 1. the rubber drain was not sitting in the drain hole and 2. the square filter in front of the fan intake was sopping wet.
When the air con is running water is coming from the drain hose beneath the car near the transmission.
Can we discount the heater core, as that water would not be clear, and coolant level in the coolant bottlle is not decreasing.
Any clues would be appreciated
