Ve v6 Manual conversion
Joshedney
Albury
Ve commodore
Hey guys, I’m converting my ve v6 from auto to manual and people are telling me different things about the computer. I have a 6spd TR6060 box, I have all the manual computer and wiring for the gear box but Some are saying that to run properly Holden needs to reprogram the car to marry it all together another mechanic is saying he can do with snap on type scan tools, what is the truth??
Also instead of reprogramming the computers and marrying things together can I just buy a manual ecu and plug it in and run the manual box and computer and wiring and will that stop any issues?? Any help would be great before I go ahead with the swap , thanks.
Shen Long
Roxby Downs
WH Caprice 5.7L
Yes that’s true, but LS Xtreme can handle all your reprogramming needs - they’re good at it too
https://lsxtreme.com.au/
Joshedney
Albury
Ve commodore
Yea sweet, so how does it work? Once I’ve have all the work done do I just send them the ecu and they will do the programming? Also do I need to get the dash cluster reprogrammed too or is that automatically done when you do the ecu?
_R_J_K_
Zenki S14
You have a TR6060 and a V6? How are you adapting it to the engine?
losh1971
North Tas
VE Series I SS Ute
Can a 6060 marry up to the V6?
Shen Long
Roxby Downs
WH Caprice 5.7L
ECU, BCM, ABS Module & Cluster all need to be programmed (but confirm this with LS Xtreme)
Shen Long
Roxby Downs
WH Caprice 5.7L
Shen Long
Roxby Downs
WH Caprice 5.7L
I see no reason why it wouldn’t or couldn’t but I don’t think they’re the factory box for the V6 engines
J_D 2.0
Ipswich
2009 VE SSV M6 on LPG and 2022 Kawasaki Z650L
Nope. Not easily anyway. You’ll want the Aisin 6 speed that was fitted to the V6 manuals from the factory.
J_D 2.0
Ipswich
If you’ve got yourself a TR6060 box you might as well go the whole hog and put a V8 in it. Putting a TR6060 behind a V6 isn’t going to be easy. Maybe you mean you’ve got an Aisin 6 speed from a V6 Commodore?
