Ve v8 l76 afm problems
Macssv
39
Ve Calais V V8
Hey there has any1 heard of these 2 codes come up
P0016
P0106
I no its sounds weird on a v8 but does any1 have any clue
Surely chains dont go in them
I was driving along as normal suddenly the car stopped on me then checked the codes they came up now the car doesnt start only the starter motoe trying to crank the car
Cheers please help
Asmodai78
VE Calais V Sportwagon
Replace your crank angle sensor, that should fix your issue
Macssv
39
Ve Calais V V8
Is this the one just near the starter motor... surely that wouldnt stop the car while driving would it..... and for those codes to come up
07GTS
Australia
VEGTS BUILT BLOWN E85
P0016 is crank sensor crankshaft position correlation
P0106 is MAP sensor range/performance
engine needs crank signal to run otherwise timing and injection cant happen, as mentioned id try crank sensor first as the map is prob just a code from the engine stopping when the crank failed
Macssv
39
Ve Calais V V8
Thanks mate ill suss that out asap... just need to find a spare 1 laying around somewhere.... hopefully it is the problem cause inhad the car booked in to get the afm dod delete kit done new cam and rollmaster chain.... but if its that winner winner cheers
