Ve - Vf engine and ecu swap
Discussion in 'General' started by Corzay, Oct 10, 2015.
  1. Corzay
    Corzay New Member
    Vf Commodore
    I should also mention the Abs if need be, along with a lot of the other electronic 'computers' separate to the ecu relating to the drive if you will.
  2. Corzay
    Corzay New Member
    Vf Commodore
    A lot of you are probably thinking this is quite the pointless task (especially relating to be apparent need of the Vf Ecu), I want to do all this for a few reasons. I want to create a mimic Vf from a Ve, I want a nice looking and functioning car, inside and out (and to be honest I hate the Ve interior), and I want something to toy around with! I'm not wanting to throw so much money away through boredom, the other reasons are obviously quite key too.
  3. _R_J_K_
    _R_J_K_ Well-Known Member
    Zenki S14
    I"d buy a VE with an LS and be done with it. Even that would be cheaper. There's playing, and then there's what you have in mind.
    Make sure you tally time and money spent for... reasons.
  4. vongy10
    vongy10 Active Member
    Gunnedah
    CV8 Monaro V2
    You said you don't have a gold mine yet everything you want done will need one. Seriously better off actually buying a VF then trying to fit it's gear into a VE without knowing if it'll actually work.
    - How much do you think a whole dash, center console and door trims will cost?
    - How much do you think all that running gear is going to cost?
    - How much do you think all of the electronics are going to cost?
    - How much do you think it's going to cost to get everything working?
    Everything you want done will cost more than the car itself....
    If you can find a wrecked VF that's cheap then have at it...
  5. Corzay
    Corzay New Member
    Vf Commodore
    I've been looking at a combination of both first and second hand parts. A lot from the wreckers, although in good condition. Some wreckers will actually legally say whether or not they can guarantee a part will work, and even give you a few months warranty. If I bought all of this brand new and had it all done professionally, it'd probably cost closer to 100k than 50k. I'm aware of said costs, I've put the time in for research. And everything I have suggested is reasonably priced, depending on whether or not a lot of Ve parts will be compatible (or able to be made compatible). My budget is ideally around the 25k mark, and as I've said, I've put the time in to come up with this number. Including a few extra thousand to go into things I'd have professionals do. And if it all went to ****, I'd just convert it back into what it originally was, and sell of the vf parts. I'd lose a couple thousand if that happened, although the amount I'm researching for this, it should be good to go. Also to be noted for those saying it will take up a lot of time, I know this, I'm not planning on using or needing this car until completion (I have another car).
  6. Hannah B
    Hannah B New Member
    NSW
    Commodore Equipe 2011 VE series II
    I'm trying to understand all this cause I've just gone under an engine swap from VE series II EQUIPE to 2012 OMEGA and my cars been showing up on the dash all these faults that aren't existent and my oxygen sensor wasn't detecting and now it doesn't start and had black smoke coming out of it when it did start.
    It was jolty when I drove it. Holden told me it shouldn't be a computer problem because its 2011 - 2014 are all the same
    But i know they are bad mechanics and don't know what they are doing
    what do i do?
  7. UnmedicatedLunatic
    UnmedicatedLunatic Member
    VEII SV6
    It would be cheaper to smack yourself in the head with a hammer until you think it looks like a vf. That or just buy one for half the price of the dumbest car project in history.
  8. CommodoreJunkie
    CommodoreJunkie New Member
    2005 Vz Sv6 commodore
    Yeah I’m thinking about swapping the LY7 in my vz sv6 for the LFX engine. Keen to hear how your build goes man!
  9. Kyemasclet
    Kyemasclet New Member
    Australia
    Ve ss
    I'm not sure if this was mentioned quite afew comments to go thru, but do any of you know if the Vf motor will pretty well fit right up in the ve?
    I'm looking at putting a 6.2 vf motor in my ve ss ute (current motor will more then likely cost me more to fix then to buy this motor in the end run) I know I'm going to need to alter my harness and most likely remapping the ecu but ofcourse only if the motors going to fit aha any insight would be appreciated
  10. Ryan.Peterson1
    Ryan.Peterson1 New Member
    2011 VE SV6 Commodore
    Corzay, did you end up doing the ECU swap for the LLT? I am looking into doing something similar as the E69 ecu in the VE is limited to tune and I am running boost. So the E39 Ecu is better suited.
    Cheers,
