A VE
sedan omega v6 weighs in at 1690kg while a VE Calais v6 weighs in at 1780kg,
specs here. That’s a 90kg difference in sedan kerb mass which must impact sedan payload...
Unfortunately that linked site doesn’t list VE ute kerb weights or GVM and I haven’t found such info elsewhere with a quick google.
Its frustrating that kerb weight & GVM info should be so difficult to find for a comercial vehicle like a ute. But it seems that Holden isn’t loose with such weight specs and motor magazines only seem to care about 0-100 times... Luckily GVM must be listed on a commercial vehicle‘s compliance plate so it’s always specified (unlike kerb or tare weight)...
But that above linked site does list VZ ute kerb weight which varies from 1669 to 1942 with a GVM 2685. I posted about this
here. The VZ upper model utes do loose considerably more than 5 kg payload due to being porky (and different rear suspension maybe?).
So just curious whether the VE ute kerb weight has been narrowed to such an extent between the base and upper spec VE utes models?
Do agree that it’s somewhat academic as few would bother actually weighing stuff they chuck in the back.... and power would be more noticeable than an overloaded ute.....
