panhead
- Jan 17, 2016
- 3,155
- 4,497
- 113
- Location
- NSW Central Coast
- Cars
@Forg @panhead, found this VE Holden Ute Brochure.
According to the brochure, the GVM is specified on the complance label while max front and rear axle weights are in the Owners Manual! Again, according to Holden's brochure, your dealer has the specs for Kerb Mass for the various models! WTF??? such information one needs to safely determine allowable max payload shouldn't be spread across various documents and a dealer... it should be defined on the compliance and other labels...
Shouldn't be so difficult for Holden to include both Kerb Mass & GVM on the compliance label and on the spec sheet within the Ute Brochure. Shouldn't be so difficult for regulators to require a new label specifying weight of an accessory be fixed on the B pillar of comercial vehicles whenever accessories are added. As is, when adding a towbar, there is a requirement for a sticker to be added which lists towbar part # and load ratings but doesn't list the bars actual weight. With a commercial vehicles, it shouldn't be difficult to work things out... ustes are comemrcial vehicles...
In @SSVREDLINE2014 case, it is probably not really so relevant whether there is even 100kg difference between base model and top model utes. Guess it depends on what and how he will use his "work" ute... I've seen plenty of work utes that don't see mud and don't often carry any loads of conseqence as it's the boss's play thing... Still, the regulators should see it as a commercial vehicle and require such info be clearly defined and readily available.
Similar is stated on this VFII Ute Brochure from Holden media site...
Totally agree, you shouldn't need to search for basic info such as payload weights for a commercial vehicle or any vehicle for that matter.
I said the same to the dealer years ago when I couldn't find the info I was after in the brochure.
