VE WAGON 2011
Kezza70
Fisherman’s paradise
VE series 2 sv6 2011
Help my ve is not firing cylinders 1,3,5
Blowing smoke and knocking noise from motor . Have change coils and plugs
Daniel Souza
46
Glenwood
VF2 Wagon SSV Redline
It would be helpful if you mention at least which engine your car has .
RossK
Australia
VE11 SV6, VF LPG Evoke
From the avatar, it'll be a 3.6L LLT, but yes more information required. What colour smoke, black, blue, white? when/why did it start, any event before hand, ie loss of coolant, oil etc, or has this just started for no apparent reason?
gossie
Gold Coast.
VE International 3.6L
And how many kilometers has it done?
Has it been regularly and PROPERLY serviced with correct fluids etc. etc.
How long have you had it....From new?
kwaka738
Wantirna, Victoria
VE MY09 Berlina Sportwagon
If it's not firing (as opposed to misfiring) I would be looking to make sure the coils on these cylinders have power (ie 12 Volts). I would be looking for something common (perhaps a electrical connector not fully home, etc).
Fu Manchu
WA.
Aren’t those injectors and coils earthed together on side of cylinder head? Another earth point on the opposite cylinder head? I could easily be wrong on that.
I’m sure someone will know for sure.
Kezza70
LLT always serviced it had oil water etc never had a problem with it . Didn’t overheat . Smoke possibly smells like burnt oil . Oil light came on car shuttered then shut off then check engine light and safety mode kicked in .
