VE wheels on VY
markbaja
VY Exec & SZ Territory Diesel
Hey fellas, I've got a VY Executive and just bought a set of VE SV6 wheels from my mate who's a wrecker for $500 with 245/45/18 tyres in great nick. I've bought a set of nuts from Holmart that have a larger flange to suit the studs on the VY, which will hold the wheel properly, and the wheels are now getting machined down, for $20 a wheel. What I'd like to know is how much will the speedo be affected by putting on these wheels? I'm coming from the stock 15s that have been on it forever.
Thanks for your help guys.
Sent from my Galaxy S2 using Tapatalk
Surfwagon
Sydney/NSW
AMG Mercedes C63 Wagon
VT-VZ 18's only run 40 series tyres and the 45's that come on VE 18's may not clear your spring mounts on the front struts as the overall tyre diameter is around 20-25mm taller (radius about 10-13mm).
markbaja
Dam, I thought it would be good, as I see 19s, even 20s on VY/VZ commodores. The tyres are virtually new, and didn't want to just remove them and buy new ones, as the only reason I bought them was for the good price.
Fletch_QLD
Brisbane Bayside
VU II SS
It's not wheel size that's an issue, 20s are fine with the correct width/profile to suit your car. 15s will rub with the wrong tyre.
Even if you got no rubber, you got the wheels for a good price. Find a second hand tyre dealer that will swap the tyres for you at little or no cost. Then you'll have no trouble with speedo, clearance or roadworthy.
Dr HaxZaw
R34 GT-T
well im running 245/35/19's and the clearance is about 4mm.... so i dont think 245/45/18s is gonna fit
RiCeY
F O R U M W A R R I O R
Australia
VZ SV8 6spd 6.0 430rwhp
Edit: misread post
RiCeY
Australia
the 18s will be 23.6mm taller than the 19s, 245/40R18s would be almost identical to 245/35R19s in height.
