Ve Window regulator issue
Paulyk123
33
Australia
Ve Ssv
Hi Guys
installed a new window regulator to my right rear door. Tested it and it worked fine.
tried again after 10 mins and she stoped working. What do you reckon the issue is. Blown fuse?
ant797
bunbury
vy s
why wouldnt you check the fuse before posting
lmoengnr
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
Try operating the window whilst moving the door, may have an intermittent connection.
Might be a broken wire in the loom through the door jamb.
JulzD
Queensland
VE SV6 Sportswagon
Hi Guys
Hey Paulyk123, question; how hard was it to get the regulator out of the door once unbolted?
My left rear on my VE SV6 wagon has gone and gotten the cable all sorts of f'd up inside the wheel. Its still all attached inside the door, but I'm trying to see if I can get it out without it being a pain in the ass.
Paulyk123
33
Australia
Ve Ssv
hey mate
wasn’t to hard, once the trim is off I taped the glass to the door To keep it in place. I didn’t take a photo but it wasn’t to hard replacing the regulator. It’s easier if you have your replacement regulator near by to compare which nuts need to be removed.
hardest part is removing the door trim but the below link will help
https://www.autoinstruct.com.au/manufacturer/holden/ve-commodore/removing-rear-door-trims/
JulzD
Queensland
VE SV6 Sportswagon
hey mate
Legend. Cheers.
I've already got the door trim, plastic and speaker all off. Now I just need to bite the bullet and remove the bloody reg.
Thanks mate. Much appreciated.
vywgn
1967 Holden HR Premier Wagon / 2015 VFII SV6 Sedan
When installing new reg, make sure the mounting plate for the window is half way down the reg will make installing so much easier
