slipknot09
Donating Member
- May 16, 2015
- 198
- 156
- 43
- Age
- 41
- Location
- Melb
- VY Calais
Honestly the tech2 can’t display 10% of the available information that these cars actually have available. Here are some PIDS you can enter into Torque to find out whether the ECM is even issuing the commands to the gearbox
Using AUTO as header should work fine, setting to 7E0 will get responses maybe 50ms quicker but not required or even noticeable unless logging.
Other PIDS which may help diagnose what sensor is playing up would be
These all should work fine, they do on my car and all GM cars of the same era if entered correctly into torque. Formulas will need adjusting to import into other apps.
I also have plenty more just for transmission but aren’t confident enough to share yet or haven’t tested enough.
I know you said you will probably just get it rebuilt but this may point you in the right direction. These may indicate your trans selector, trans fluid switch, Input shaft speed sensor, PC solenoid, Torque Convertor Clutch or even ECM may be the issue
Upshift Requested | Up Req | 22192301 | lookup(bit(A:0)::1='ON':0='OFF') |
Upshift in Progress | Upshift | 22192301 | lookup(bit(A:1)::1='ON':0='OFF') |
Upshift Desired | Upshift Des | 22192301 | lookup(bit(A:2)::1='ON':0='OFF') |
Downshift Requested | Downshift Req | 22192301 | lookup(bit(A:3)::1='ON':0='OFF') |
Downshift in Progress | Downshift | 22192301 | lookup(bit(A:4)::1='ON':0='OFF') |
Downshift Desired | Downshift Des | 22192301 | lookup(bit(A:5)::1='ON':0='OFF') |
3-2 Downshift Started | 3-2 start | 22192301 | lookup(bit(A:6)::1='ON':0='OFF') |
1923-7: 3-2 Downshift in Progress | 3-2 shifting | 22192301 | lookup(bit(A:7)::1='ON':0='OFF') |
Transmission Input Shaft Speed | Trans Input | 22194101 | ((A*256)+B)*0.125 | 0 | 8000 | RPM |
Transmission Output Shaft Speed | Trans Output | 22194201 | ((A*256)+B)*0.125 | 0 | 8000 | RPM |
TCC PWM Duty Cycle | TCC PWM | 22197001 | A/2.55 | 0 | 100 | % |
TCC PWM Active | TCC PWM T | 22197001 | LOOKUP(A::0='OFF':1~255=A/2.55) | 0 | 100 | % |
PC Solenoid Duty Cycle % | PCS % | 22197201 | (A*255)/100 | 0 | 100 | % |
TCC Slip Speed | TCC Slip | 22199101 | ((A*256)+B)/8 | 0 | 10000 | RPM |
Shift Time Error for Latest Shift | Shift.Error | 22199601 | A/40 | 0 | 70 | Seconds |
1 - 2 Shift Error | Shft 1-2 E | 22199701 | A/40 | 0 | 70 | Seconds |
2 - 3 Shift Error | Shft 2-3 E | 22199801 | A/40 | 0 | 70 | Seconds |
3 - 4 Shift Error | Shft 3-4 E | 22199901 | A/40 | 0 | 70 | Seconds |
Current Gear | Gear | 22199A01 | A | 0 | 4 | Gear |
Variable Bleed Solenoid Pressure | VBS.Pres | 22199D01 | A | 0 | 90 | Psi |
Pressure Control Solenoid Actual Current | PC.Sol.Cur | 22199E01 | A*0.0195 | 0 | 1.2 | Amps |
Pressure Control Solenoid Desired Current | PC.Sol.Ref | 22199F01 | A*0.0195 | 0 | 1.2 | Amps |
Shift Delay | Shift Delay | 2219A001 | A | 0 | 70 | Seconds |
TCC Apply Time | TCCApplyTime | 2219FF01 | A/40 | 0 | 6 | Secs |
Speed Ratio | SpeedRatio | 221A0201 | ((A*256)+B) | 0 | 2500 | :1 |
TCC Mode | TCCMode | 221A1301 | A | 0 | 4 | |
Trans Range switch | ||||||
Park | PARK | 22111301 | lookup(bit(A:0)::1='ON':0='OFF') | |||
Reverse | REVERSE | 22111301 | lookup(bit(A:1)::1='ON':0='OFF') | |||
Neutral | NEUTRAL | 22111301 | lookup(bit(A:2)::1='ON':0='OFF') | |||
Drive | DRIVE | 22111301 | lookup(bit(A:3)::1='ON':0='OFF') | |||
Third | THIRD | 22111301 | lookup(bit(A:4)::1='ON':0='OFF') | |||
Second | SECOND | 22111301 | lookup(bit(A:5)::1='ON':0='OFF') | |||
First | FIRST | 22111301 | lookup(bit(A:6)::1='ON':0='OFF') | |||
Invalid | Invalid | 22111301 | lookup(bit(A:7)::1='ON':0='OFF') | |||
Trans Fluid Pressure switches | ||||||
1st Gear | FIRST | 22192101 | lookup(bit(A:0)::1='1':0='OFF') | |||
2nd | SECOND | 22192101 | lookup(bit(A:1)::1='2':0='OFF') | |||
3rd | THIRD | 22192101 | lookup(bit(A:2)::1='3':0='OFF') | |||
Drive | DRIVE | 22192101 | lookup(bit(A:3)::1='D':0='OFF') | |||
Rev | REVERSE | 22192101 | lookup(bit(A:5)::1='R':0='OFF') | |||
Park/Neutral | P/N | 22192101 | lookup(bit(A:6)::1='P/N':0='OFF') |
