Merv53
- Jan 19, 2019
- 81
- 17
- 8
- Age
- 70
- Location
- Toowoomba Qld
- VF series 2 SSV
Hi everyone
I knew I would not be driving my VF ss for a fair period so I sought the advice of Holden re
the best way to store the vehicle. Here is their reply for anyone who might be interested.
Hi Merv,
Thank you for writing to Holden customer care, we appriciate that you are doing everything you can to take care of your car! Below I have listed the recommended way to store your car for long periods of time;
Storing for days
Prep the vehicle as following:
Yours sincerely,
Wendy - Holden Customer Care
Hi Merv,
Storing for days
- Ensure all tyre pressures are to the stated level on the tyre placard located on the vehicle.
- No more than ½ a tank worth of fuel in the vehicle.
- If left in a cooler climate: ensure the adequate pest control is in place (mouse/rat bate/taps) in the storage location.
- Raise tyre pressures to the maximum pressure rating listed on the tyre wall to ensure no flat spots will form.
- No more than ½ of a tank of fuel for 1–2 weeks of storage and no more than ¼ of a tank of fuel for longer periods.
- Once the vehicle is in the storage location, disconnect the negative (-) battery cable if left for less than 3 weeks. Disconnect both negative and positive battery cables if left for more than 3 weeks. (Always disconnect the negative battery cable first!)
- Ensure all fluid levels (oil, coolant etc.) are at the maximum level (if top up of fluids are needed, use recommended fluids outlined in the owner’s manual and service handbook).
- If vehicle is exposed to outside conditions, do not park the vehicle under trees/bushes that drop leaves, sap and other debris as extend time on paint work with cause damage. If possible, place a cover over the vehicle.
Yours sincerely,
