Ventilation Valve
colincritter
VS Commodore Ute
Can anyone tell me where the one way vacuum valve should be in a VS Ute.
Cannot find it on a vacuum line under the bonnet.
Should it be there or behind the dash ?
accentstencil
71
Caboolture South, QLD
WH II Caprice, 5.7 2018 Equinox LTZ V
Usually it is at the rear of the intake manifold near the firewall.
colincritter
VS Commodore Ute
Is it the silver valve with a small hose coming from the manifold into it and a larger hose that then goes into a metal pipe and into the firewall or should I be looking for a valve on the line from the vacuum tank under the LH front wheel ?
accentstencil
71
It should be a small white round plastic valve with a thin vacuum hose connected to both ends. It's about as round as a 10 cent piece and cylindrical in shape.
Here is a pic of one from a VT but it should be similar.
