07GTS
- Sep 8, 2013
- 4,957
- 6,512
- 113
- Location
- Australia
- VEGTS BUILT BLOWN E85
do u still have that plastic piece (right angle bent) that is under the radiator ? that helps increase airspeed after the radiator to help draw air thru it when driving, the LS being alloy does dispate alot of heat so it will be hotter then a iron block that holds in heat a little more but u should be able to set fan temps to come on at 95-100 and it should have no issues keeping it that temp driving normal, if it cant then there is a issue with flow or fans
