Also, I've found that if you reset your battery on sloping ground you can have way more or less fuel than the computer thinks.
Hey guys, if a VY Calais II shows a ‘very low fuel’ warning on system check, will that disallow the engine to start? As in, the engine wont even attempt to turn over? Thanks
Do you know what angle the car has to be to fool the sensor into registering more fuel then what there is - nose down hill, or up hill? Thanks
