Very Rookie Question, what is a shift kit??
Jonesy484
OfficialChadyMeetOrganisr
Melbourne. Victoria
MY12 VE 2 SSV REDLINE WAGON
Guys this is a very Rookie question,
What the hell is a shift kit?
What does it do?
Why should i get one?
How much?
Cheers Jonesy
PirateJoe
VS ute, YZF-R6
A shift kit is fitted to the valve body inside an automatic transmission to change the shifting times or adaption pressure between gear changes. So it can hold a gear for a longer period of time.
You shouldnt necessarily get one one. You could consider it if you been modifying your car already or plan to it along with some other modifications to your car.
$45.70 f**k knows.
DevilDRake
Braaaap
Skye
www.devildrake.deviantart.com
2006 VZ SS 6L Ute
As said it above, gives alot better stronger shifts at high revs, only thing is if you Granny it it's very uncomfortable for some people.
You can get the Corvette servo + Stage II shift kit fitted for around $350 in Bayswater Automotive.
