Very sluggish power steering
PlenumBiscuit
VY Commodore
steering it is like an old valiant at the moment (barely has power steering)
tyres are good, no fluid leaks, no noises
ive heard theres a way to reset or get air out of the lines ? go full lock side to side for 5 minutes or something??
anyway to know if the rack is stuffed
krusing
My VY had a similar issue, felt like "Truck Steering"
Some time ago, I didn't want to tackle it,
so I sent to a local mechanic, and he installed a C/O Pedder's Power Steering Rack,
I did ask him to replace the Power Steering Pump, but he said it didn't need replacing,
a little while later, the steering got heavy again and started vibrating/growning again.
I then purchased a Power Steering Pump from eBay, to suit the VY L67 Calais variant,
And that fixed the heavy, vibrating/growning steering.
That said, in your situation, the cheaper option first up, would be replace the Power Steering Pump first.
PlenumBiscuit
VY Commodore
When u take the pump out there's something I remember is severely important such gotta fill the pump first or bleed the lines or bleed the rack or something
Can't just swap a new pump in, gotta do something do something to hold the pressure is it?
Immortality
Staff member
Sth Auck, NZ
HSV VS Senator, VT s2 Exec, VX Calais II L67
You can put the pump in and then tip a little fluid into it before plumbing up the reservoir hose. You can spin the pump by hand to prime the system. I flushed the power steering in my Subaru recently by turning the pump by hand and putting the return line into a old container.
Once the system is fully plumbed up, fill the reservoir and start the engine and shut it off before reservoir runs empty, do this still the reservoir remains full, then slowly turn the steering lock to lock a few times topping up the reservoir as required. I prefer doing this with the car jacked up do there is no weight on the front tires.
If you get air into the system and aerate the fluid you'll need to stop and let it settle for a bit.
greenacc
Searching for the billion
VE Berlina
Tell me the fluid has never been changed? First thing I'd be trying is some nice new fluid. Now I know this is not a VE, but I put this fluid in my VE and it made the steering feel like a Rolls Royce.. so check it out.
PlenumBiscuit
VY Commodore
Thanks guys I changed the steering wheel cover and now all seems good again....nah only kidding
Will get a new pump I suppose and some new fluid thanks
Not nulon though that's recycled and cheap
BlackVXGTS
Melbourne, SE
From the Holden VT/VZ Service Manual:
BLEEDING/REFILLING PROCEDURE
1. Raise the front of the vehicle and place on safety stands.
2. With the engine not running, add the power steering fluid to reservoir to the maximum mark (or greater, if it is
known that the steering gear is empty).
3. Start the engine and allow to run for only 2-3 seconds. Do not turn the steering wheel at this point.
4. Continue with Steps 2 and 3 until the power steering fluid level remains constant.
5. Start and run the engine at idle speed, turning the steering wheel from lock to lock, without holding at the full
lock positions (this will build up high pressures, atomising any entrapped air). Repeat this procedure from six to
eight times. Stop the engine, check the power steering fluid level and top up to the maximum level, as required.
6. Start and run the engine at idle speed. Again turn the steering wheel from lock to lock but now slowly build up
the pressure levels by holding against the full lock position from 1-2 seconds. Repeat this procedure from four
to six times. Stop the engine and top up the power steering fluid level to the maximum mark, as required.
NOTE: While the majority of entrapped air will be removed by the above process, a small amount may remain,
which can only be removed by alternate circulation and settling of the power steering fluid for a prolonged period.
This is usually achieved automatically after two to three days, with daily driving and settling overnight.
7. Turn the steering wheel to the straight ahead position, lower vehicle to the ground and turn ignition 'OFF'.
PlenumBiscuit
VY Commodore
Legend thanks so much for sharing that very kind good karma for you kind sir
How max fluid am i gonna need? bugger all i suspect... 1 to 2 litres?
BlackVXGTS
Melbourne, SE
Manual says 650ml, but I guess it depends on whether you have a power steering cooler installed. One litre of Dex3 should be plenty.
PlenumBiscuit
VY Commodore
tried to change the pump over and the frikken hose is seized in the back of the old pump grrr
tried a heat torch on it 4 times and wouldnt budge. got a proper 16mm pipe spanner still no good
so now i need a new hose for the new pump omg
and guess what mine is a series 2 that uses a extra long weird high pressure hose, that the vt vx vy s1, dont use omg
series 2 hose
and the easy to get
series 1 hose
what is this
VARITRONIC thing​
