Vf alloys to fit Vn Calais
Mat OHara
52
New Zealand
Vn 5.0 Calais
Can anyone tell me if spacers on the front of my Vn Calais will stop the( vf wheels I’ve had machined to fit) rubbing on the bottom of the suspension springs? Cheers
VS 5.0
Are the wheels rubbing, or the tyres ?
If the tyres, then I expect you have the incorrect tyre size/profile fitted.
What size rim & tyre combo are you running ?
Tonner Matt
Darwin
VZ 1 Tonner LS1 M6
A little extra info to add to the advice received in the other thread you posted in....
# You don't need spacers
# It is a well known issue that the VE/VF 18" tyre size of 245/45-18 will rub on the bottom of the strut on pre VE/VF commodores
# You'll need to fit the correct tyre size of 235/40-18 to clear the bottom of the strut
