it should run better, may or may not get better consumption prob will average out the same, just the first week back might be higherThe mechanic also mentioned the car will run better aswell and also reduce fuel consumption...
Update, so now their going to delete the amf and also put an LS3 cam in and retune the motor, also said the car will run better on fuel...will this have any impact on power...2 months without a car because of ticking lifters? Even in COVID infected Rackoon city (Melbourne), it wouldn't taken so long to fix this... Something is odd and i wouldn't be a happy camper if it was my car
So how old is your car and how many kms has it done? Did you disuss this problems with a dealer before going 3rd party? If so what did they say was wrong? How much did the 3rd party mechanic quote to repair your car? Which cylinders aren't working (AFM shuts down cylinders 1, 7, 6 & 4)?
Normally, someone would reprogram the ECU to remove the AFM feature if they have installed a new more agressive cam that AFM lifters can't cope with. They'd then install new (normal) lifters (not the AFM ones) along with a new valley plate (to replace the VLOM). BUT such is done if your chasing power. If you just want noisy lifters fixed, it should just be new lifters and maybe a new standard cam (if worn).
If you've retained the AFM feature, reprograming wont help some crushed wiring that earths the VLOM solenoids (as that's the only fault i can think of that would sut down the AFM cylinders at startup).
It all seems odd and the mechanic needs to clearly explain the problem to you so you fully understand the repair... Go and ask the meachanic fixing your car to explain what he's done, what the problem is and how he's going to fix it ... and take a friend that understands cars with you
It all sounds confusing as it's a warranty claim yet you have to pay something ($1500) out of pocket while the mechanic couldn't fix a simple lifter issue on an AFM V8. I'd still focus on sorting out the warranty side and why AFM now doesn't work (something any capable mechanic should be able to explain)...Update, so now their going to delete the amf and also put an LS3 cam in and retune the motor, also said the car will run better on fuel...will this have any impact on power...
