Turbski
- May 13, 2024
- 1
- 0
- 1
- Age
- 20
- Location
- Victoria
- 2014 VF V6 Calais V Wagon , 2005 VZ SVZ V6 Wagon
Hi all,
I am having quite an issue after doing my sound system install, No matter what gain settings are used, my system seems to distort, even after lowering the gains on the Hi-LOW rca converter, or even on the amp itself,
the system sounds mint until around 25 volume, when using bluetooth primarily and i feel with the parts i have chosen it is fairly balanced.
all settings in the mylink eq are set to flat (Even lowering these makes little to no difference with distortion levels.
i am at the moment contemplating whether i replace the head unit with an aftermarket one, but doing this would be a bummer because i just spent 900$ a month or so ago on the import road carplay unit and i haven't really found a suitable replacement that retains all the standard features.
another option is to take it and have the system professonaly tuned, but i feel this won't help anything as no matter what the gains are set to i have distortion (This has been confirmed using an oscilloscope).
Do i need some sort of Audio processor maybe?
One way i managed to sort of avoid this issue was to turn both the Hi to low converter and amp gains up by heaps and just dont turn the radio up past 25 volume or so, but this introduces the problem that the turn signals are unbareably loud with this which is no good as well.
as far as im aware all the connections are good.
let us know your thoughts or if anyone has had this issue before.
Here is a rundown of the parts used
Headunit: Standard VF Calais V S1 Headunit with the import road carplay unit
Amp: Alpine PDX V9 5Ch
Door speakers: Polk audio mm6502 (Front) Polk audio mm650 (Rear)
Hi to low converter (HAS A CUSTOM HARNESS INCLUDED) : https://www.universalfuze.com/product-page/rca-output-converter-hi-low-for-holden-commodore
(Aerpro 4 Channel High to Low Audio Level Converter AP3044A)
Sub: Alpine 12Inch Type R sub (SBR-S12D4)
Wiring kit: 4AWG
Speaker wiring : 14 awg speaker cable
One further detail is i had this exact system in my VZ Svz wagon with a pioneer avic-z930dab head unit with not a single issue, sound was clear asf, with little to no distortion, and was so much louder.
At this point i think its the headunit or something to do with it, what do people suggest to fix this issue, if i can idealy keep the standard headunit that would be my first preference.
thanks everyone
Wiring kit: 4AWG
thanks everyone
