I have an Issue with the Windscreen Washer Motor not working have tried replacing motor but found no power at wiring checked fuses all good, replaced Wiper control Switch no Change, have noticed that the automatic control feature also dosn't work as well
There will only be power at the connector when the washer is activated. You will need two people to test it.
Use an incandescent test light, not an LED test light. Do not shove the test probe into the pin. Just touch it on the pin. Otherwise you can spay the pin terminal and it’s a bad connection. Earth the light to the body first to confirm power. Then try Earth it via the other pin in the connector. Should be a two pin connector. A modified Saftey pin works well. Insulate it from accidental contact though. Repeat the test to confirm the circuit works.
When disconnecting the battery, disconnect negative terminal first.
Leave it disconnected for an hour or two if you can, or over night.
