In Victoria it's illegal to leave a car with the engine running. Don't do it.
Road Safety Road Rules 2009 penalty code 2135
It's not just illegal to leave the engine running it seems
For those interested in the text of the law, it's linked and repeted below:
ROAD SAFETY ROAD RULES 2009 (SR NO 94 OF 2009) - REG 213
Making a motor vehicle secure
driver of a motor vehicle who stops and leaves the vehicle on a road, except so far as the driver is exempt from this rule under subrules (7) or (8).
Note
Motor vehicle is defined in the
Road Safety Act 1986 .
(2) Before leaving the vehicle, the driver must apply the parking brake effectively or, if weather conditions (for example, snow) would prevent the effective operation of the parking brake, effectively restrain the motor vehicle's movement in another way.
Penalty: 3 penalty units.
(3) If the driver will be over 3 metres from the closest part of the vehicle, the driver must switch off the engine before leaving the vehicle.
(4) If the driver will be over 3 metres from the closest part of the vehicle, and—
(i) there is no-one left in the vehicle; or
(ii) there is only a child or children under 16 years old left in the vehicle—
the driver must remove the ignition key before leaving the vehicle.
(5) If the driver will be over 3 metres from the closest part of the and there is no-one left in the vehicle, the driver must—
(a) if the windows of the vehicle can be secured—secure the windows immediately before leaving the vehicle; and
(b) if the doors of the vehicle can be locked—lock the doors immediately after leaving the vehicle.
Note
Window is defined in the dictionary.
(6) For the purposes of subrule (5), a window is secure even if it is open by up to 2 centimetres.
(7) Subrules (3), (4) and (5) do not apply to the driver of a vehicle acting in accordance with an exemption from the application of those subrules granted by the Corporation under subrule (8).
(8) The Corporation may exempt a driver of a vehicle or class of vehicles from the requirements of subrules (3), (4) or (5) subject to any conditions the Corporation thinks fit.
