J
Jingle Bells
Guest
Hi All,
Can anyone steer me in the right direction.....if you have a collision and the all the doors are locked electronically and the tabs are below the window sill level ....how do you exit the vehicle...I know that the doors are supposed to open when it senses a collision has taken place....but if the computer is damaged and fails to operate the door locks...and /or you cannot open the doors internally or externally....as it happened in America yesterday...they had to smash the window and drag the driver out ????????.....an interesting situation !
Well I suppose you can drive with all the doors unlocked....that is not a problem...but it leaves you with the prospect of a high jacking at the stop lights...and /or the super market in the big smoke and concrete jungle if you are a female driver ....which is becoming more common these days....I always operate the vehicle so that the first push on the key only operates the drivers door and then automatically locks when you turn the ignition on.
