VF Commodore "DOC" connector..
Sparkal
Auckland, NZ
2014 VF SV6
Sorry for my ignorance, but RAP pin is? Switched 12v(ish) supply? So on an off with Ignition.
wayneus
Yass, New South Wales, Australia
VF SSV REDLINE
Nice find! Is there a similar connector in the boot? All my stereo gear is in there...way easier to trigger an amp from there for me! Sick of manually using a switch (which I put in the boot)...
wayneus
VF SSV REDLINE
I found the RAP (thanks to another post on the forum)...in the rear near the battery, hooked it up to my PS8! All good! Pretty easy to find as well. I pulled the fuse and put a wire into the fuse holder, then put the fuse back in. Will put a pic up to show!
attachment.php
attachment.php
richo7502000
51
Sunbury, Victoria
Gen F GTS, Harley Davidson VRSCF V-Rod Muscle
I have just bought a Blackvue DR650GW-1CH Car camera, it also has the Power magic Pro Battery discharge prevention device. Id love to see the pics of where you hid all of the unit, and how you ran the wires up the A-pillar.
I was looking for the wiring connections for B+ and RAP, so your post has been very handy for that thankyou.
regards
Richo
VinnieLS3
VFII Commodore SSV Redline
regards
Richo
Same here.. looking to get the same model but 2CH
CalaisNQ
Mackay, Qld
VF II Calais V V8 , VS Calais, VS Ute & VZ SV6
Has anyone measure the connector?
I think can have found the plug that will fit the connector, that can be ordered from the USA.
The dimension of the DOC connector under dash should be W: 33.7mm X H: 27.1mm Pin width: 2.8mm.
I'm looking to purchase a few plugs to fit, if anyone is interested.
Would like to order them while they are available now, my new car is still 2-3 weeks away.
Snicko1
40
Australia
VF Calais Wagon
Let me know from where and what part no and ill order one or two!
dgp
VF II SSV Redline
I will take one, add me to the list.
CalaisNQ
Mackay, Qld
It's way too expensive to buy just 1 or 2, cost would be $85 for one connector, (there's a min $50 spend before freight).
I'm willing purchase 7 and female connectors to suit that will bring the cost down to $20 each.
Just won't someone to confirm measurements of the connector in the car.
ToeCutter21
Central West NSW
VF Redline MY15 + VF2 Redline MY17
Can anyone post pics of finished product?
I'm interested in the page 3 post referring to removing roof trip to run cable. How is it removed and put back into place? I'd have nightmares about stuffing it and having it hang down forever.
