VF Commodore HID Kits
VFSSVUTE
VF SSV Commodore Ute
Hey guys,
Just wondering if anyone has installed HID kit in there VF Commodores yet. If so are they the all in one with internal ballasts or do they external ballasts?
jasonjea
Sefton
www.aus-chat.com
VF Commodore SV6 UTE
Cant wait to see. Im ordering one now.
Sent from my GT-I9505 using Tapatalk
Tenpinrob
South Morang
VF SSV Redline
Looks good, like the idea of no external ballasts. I think I will wait it April and do the high beam at the same time, getting to them looks painful
PIR4TE
Banned
AWOL with Ari
Black Pearl
I have the exact same units in 5000k, don't get 6000k is too blue, makes car stand out to police and you will eventually get busted as I did.
Of course these are all illegal, will void your insurance and third party blah blah, so make some enquiries about 5000k (max white light slight blue/greenish on startup) or 4300k (typical headlight whitish slight yellow), same vision and benefits.
Never put in lens without projector, you will need to adjust your beams, you will void all insurance cover at night.
VFSSVUTE
They look pretty good. will order a pair of them. does anyone no what type globes the indicators and park lughts are because il get some led oned to suit the hids
VFSSVUTE
Have any of you guys received and installed your hids yet? how are they
VFSSVUTE
i know they will be illegal. but i would still like to see how they are
lacks creativity
35
VF SV6 Manual
Ok, I have completed the HID install, it was painful and annoying
First you will need to rotate your wheels so you can access the torx screws
Then you will need to remove these, there are 5 you need to remove, this will allow you to move the inner liner back, dont worry they bend
Then the tricky part begins you will need to reach up inside and remove the back dust covers, then disconnect the power, unclip the metal clamp and remove the bulb, you can barely see a single thing when doing this so its a lot of feeling around.
once you have done that you can then plug the HID ballast into the power, once this is completed it best to plug the bulb in while hanging outside the headlight to test, if it doesn't turn on the first time don't panic, reverse the plug for power and it should come on, it should look like this.
Once you are happy, tuck the cables in the headlight housing and screw on the ballast which replaces the old dust cover.
Repeat the process for the other side and done :)
Also keep in mind you might get pinned by the police for these, for me I dont drive a great deal at night so I am happy to run the risk
