VF Commodore HID Kits
Discussion in 'VF Holden Commodore (2013 - 2017)' started by VFSSVUTE, Feb 17, 2014.
  1. KING46Calais V
    KING46Calais V Active Member
    2017 VFII Calais V 6.2L Sed
    LED do have a clearer colour but you're right LED don t throw the light as far as a halogen.
    This might be fine for city driving but you notice it on freeway, high speed driving.
    As much as I wanted to swap over to LED, I ended up going with HID as it has better colour than halogens and close to LED but has a much better light throw than both of them.
    I Have HID in both Hi and low beam.
    I'm sure I posted some photos earlier in this thread
    abuch47 likes this.
  2. Fu Manchu
    Fu Manchu Well-Known Member
    WA.
    Slug powered VZ, a VE Calais & your mum.
    I fitted the H11 to the high beam on my VE. The cap goes on ok. Seems a super tight fit though. Not sure there is much of a gap under it between the dust cap and the back of the LED fan.
    Is that the experience of those with a VF?
    I understand they are a different assembly.
  3. Poor old Dad
    Poor old Dad Active Member
    VFII Calais V
    There's plenty of room.
    I didn't take a lot of notice (nothing of concern noted) and I can't actually recall but if I had to take a guess I'd say there's at least 20mm between the back of the fan and the dustcap.
  4. Fu Manchu
    WA.
    I might have 2mm on the VE using the same globes.
    I do have a bigger dust cover coming for the low beam. A dust cover spacer would be good on the high beam.
  5. Poor old Dad
    VFII Calais V
    EDIT: Sorry Fu, I was getting confused with low beam as they're the ones I did last.
    High beam... hmm, again I really can't remember but I'm sure if there was a potential issue I would have noticed it.
    I'd have a look for you but we're leaving for a trip in the morning and car has carbra on.
  6. Fu Manchu
    WA.
    There’s some jokes there, but they are lame. If you could check it out, it would be good.
  7. stooge
    stooge Well-Known Member
    wa
    VF SSV
    Had my hi beam ones in for ages and i do alot of night driving on country roads to and from the mine sites with no problems so i doubt there is any issue with airflow.
  8. Fu Manchu
    WA.
    Only mentioning it because the VE has different dust covers. Doesn’t seem to be as much room for high beam as the VF. I installed a high beam LED and the dust cap comes close to touching.
    Low beam, there is no chance of the LED fitting.
    There are some crummy rubber covers available.
    Would be good to have a spacer or alternative hard plastic cover available.
  9. stooge
    wa
    VF SSV
    Snapped a pic of the led hibeams
  10. abuch47
    abuch47 Active Member
    Madelaide
    LSS3 YOOTE
    H7 in a projector for lowbeam?
    H8/9/10/11 in a reflector for highbeam?
    parking lights what type?
  11. stooge
    wa
    VF SSV
    I just use the ultra blue halogens in my low beam and they are not brighter it is just more of a white color temp
    https://www.repco.com.au/en/brands/narva/narva-h7-px26d-ultra-blue-globe-12v-55w/p/A9372057
    with parkers you can just use any cheap wedge led, I use these ones
    https://www.supercheapauto.com.au/p/sca-sca-interior-globe-10-smd-led---super-white-t10/382403.html
    when fitting the nighteye high beam globes in the vf you need to make sure the orientation of the led chips is horizontal(9 and 3 oclock) because the bulb can fit in 2 ways and the light throw is screwed up if it is in the wrong way.
  12. abuch47
    Madelaide
    LSS3 YOOTE
    Yes Ive seen 9 & 3 mentioned with most LED suppliers. Probably going to give the best rated ones a crack from bulbfacts.
  13. Redline 2017
    Redline 2017 Active Member
    Goulburn
    2017 VF 2 SSV REDLINE
    Night eyes... Just the H9 LED replacement? Nice light throw, I'm buying these.
  14. Fu Manchu
    WA.
    Before I can use these, or others, on the VE, I will need deeper dust covers 3D printed. What’s good about that is the VZ SS lights will also benefit because they share the same dust covers for high and low beam as the VE high beam dust cover.
  15. abuch47
    Madelaide
    LSS3 YOOTE
    Will a H8 LED fit the H9 high beam housing and socket or is it safer to go H11?
  16. Fu Manchu
    WA.
    H11 and H9 are mostly compatible/interchangeable with each other.
  17. stooge
    wa
    VF SSV
    The main difference in fitment is a little plastic tab in the plug.
  18. abuch47
    Madelaide
    LSS3 YOOTE
    So with halogen generally the H9 is brighter than H11 which is brighter than H8, would this be the same with LEDs?
    If its illegal in SA (most likely) Ill probably stick with brighter(shorter lifespan) halogens. stock ones seemed dangerous in the rain last night.
  19. stooge
    wa
    VF SSV
    The nighteye leds are the same bulb/kit for h8/h9/h11.
    They all fit in the same socket and have the tab removed from the plug.
    I wouldnt worry too much about legality if you dont drive in a way that attracts attention.
    Be careful running higher wattage halogens because if they produce too much heat they can melt the reflector/housing.
  20. abuch47
    Madelaide
    LSS3 YOOTE
    Ta I'm more worried about inevitable insurance issues than defects. Appreciate the response so when a supplier lists h8/h9/h11 they mean it will fit any of those
