vombil
any chance of a clearer pic of them mate? I can't make out much of the info at all. thanksif anyone is interested.
Here is one of the fixes I had done recently.
Went and ordered the part today.if anyone is interested.
I think I will do this, as I had this complaint during warranty and the seat base was replaced which the bulitin clearly says doesn't need done and they always manage to to mess something up. EG the Power control panel on the side wasn't fixed to the seat when I got it back.Went and ordered the part today.
Fitted it myself in 5 mins, no more clicky clicky.
Yes it should be a warranty job but it usually takes 2 visits to get somrthing fixed at the local dealership. For $7.50 it was worth not having to go in twice and I know that it wasn't fitted by some greasy apprentice with no idea.
To be honest I ain't complaining if they replace the seat base - new seat base!!I think I will do this, as I had this complaint during warranty and the seat base was replaced which the bulitin clearly says doesn't need done and they always manage to to mess something up. EG the Power control panel on the side wasn't fixed to the seat when I got it back.
Why 4? You only need 1 per seat if it the pkastic piece.To be honest I ain't complaining if they replace the seat base - new seat base!!
Thanks for the tip. I called up my local dealer for a quote and will be getting some ($5.80 each, arriving Tuesday). I have a slight click in my Calais driver seat that is apparent on uneven road surfaces as well. However I am sure that by the time I get that diagnosed through a test drive by my dealer (after the service), then needing to return to them for the fitment a second time, the petrol cost means I'm better off doing it myself.
I have ordered 4 as the Calais and Director have the 8 way adjustment on both the driver and passengers seats. However going off people's posts here, it seems to be the driver's seat only. Is anyone's passenger seat affected too?
I'm going to assume the stuff underneath to fit that clip is symmetrical between the passenger and driver seats .
^ my driver seat clicks when getting in and out as does occasionally my passenger seat. Dealer fixed drivers seat but said passenger seat (which still occasionally clicks) was no fault found
Not sure what was done or whether it’s the same issue as that addressed by the new clips but drivers seat is ok now
Hm, I was under the impression there were a couple of issues with the seat that needed addressing so assume the clip doesn’t fix them all. But maybe I’m miss remembering... Skylarking helped confirm above that the passenger seat is affected too. So I need 2 in the Calais, 2 in the Director!
