Hi everyone still quite new to this group. Just wondering if anyone knows how to adjust the headlights on a 2017 VF Series II SV6? Cheers in advance!!!
Is it the up /down adjustment you're wanting. There should be a small screw driver slot facing upwards towards your bonnet.
Winding this will adjust the up/down movement of the focal point. Do this against a wall/garage door at night at a distance of about 5 metres. A little piece of tape on the wall/door for the original focal point then move it from there.
Just note that Holden VF/VF2 headlamps only have a vertical (up/down) adjustment as Holden saw fit not to provide any horizontal (left/right) adjustment being the tight arses they are
Turn the adjustment screw clockwise to raise the beam and counterclockwise to lower the beam.
Just to let you know propper adjustment needs to be carried out on a head light beam aligner. Failure to do so can make the car defectable. All inspection stations for RTA ect accross Australia have these beam alinglers and will check your lights. We have one at work.
Yea if you only go a touch in adjustment it's okay but too much and you could be pulled over.
