Has anybody attempted and been successful in replacing the headlight bulbs in a VF SV6 / SS ? after much studying of the 1 page within the manual, I have almost given up all hope besides removing the front bar and the headlight to perform this, any advice would be greatly appreciated for a nub like myself.
i changed my headlight globes a couple of months ago to some philips crystal visions. i thought, "this should be a breeze" but definitely wasn't! took about an hour all up (from working out how to get to the globe).
you'll need plenty of patience and it can be done without removing the front bar. for the passenger side make sure you remove the air filter for better access. it's a tight squeeze but is possible.
for the drivers side, you'll need to remove the coolant tube (like it says in the manual) but also remove a grey unit (i think the ECU?) and you can get your hands underneath. You'll obviously need to unscrew the caps to the globe and just pop the globes out.
This probably isn't helping much as it's a bit hard to explain but yes it can be done.
I'll see if i can take some pics over the weekend to show you what i did...
