VF Holden Commodore Issues and Faults
Discussion in 'VF Holden Commodore (2013 - 2017)' started by Krustyone, Jun 21, 2013.
  1. The1985divo
    The1985divo Active Member
    VF Calais V
    Have the same rattle with the passenger and driver seatbelt mech, VERY annoying, hopefully something can be done when it goes for its service.
    The cover for my sunroof rattles too, hopefully that can be tightened
  2. The1985divo
    VF Calais V
    Yea, that was a common prob, should have been sorted before you took delivery.
  3. duaned
    duaned Active Member
    Newcastle NSW
    M6 Red Hot MSE
    I have an annoying rattle coming to be what sounds like the inertia reel for the rear seat centre passenger. I know these things have a ball bearing or something inside them but mine rattles like crazy over rough roads. Anyone else have this?
  4. Luke V8
    Luke V8 AKA Luke!
    VE Commodore SSV
    I have a rattle, sounds like plastic rattling or similar ... Can't work out where its coming from and it's stopping me from lowering the car as can't run the risk of Holden blaming the stiffer ride.
    Sent from my iPhone using Tapatalk
  5. cfour
    cfour Member
    Coming Soon
    Check the passenger seatbelt and sunroof cover.
  6. zappaboy
    zappaboy Active Member
    VF Calais V V6 Sportswagon, Motorsport Auto VE Ute
    I have experienced the mylink to reboot itself once and maybe 2-3 times freeze for a few seconds and then work ok. It is a computer and fortunately it is not windows based like the ford system.
  7. Fekason
    Fekason Fekason
    Penrith NSW
    The following is not a complaint, just a comparison.
    I have just added a VF SV6 Manual to my 2013 MY12.5 VE SV6 Z Manual. I assume that most would know the additions with the latest model, but I have been a little surprised to notice a few deletions.
    The Z had individual map lights in the front. The VF does not.
    The Z had tilt function on the driver's seat. The VF does not.
  8. RoganJosh
    RoganJosh Active Member
    Holden VF Calais V -V6
    Yes it is windows based didn't you notice the Windows Vista touchscreen in Mylink module.
    Sent from my iPad using Tapatalk
  9. PIR4TE
    PIR4TE Banned
    AWOL with Ari
    Black Pearl
    Not Windows.
  10. Fekason
    Fekason Fekason
    Penrith NSW
    Another deletion:
    VE SV6 Z has fog lamps. VF SV6 does not.
    The rear camera in the VE SV6Z has guidelines to assist. The VF just provides the picture.
  11. Freestyla
    Freestyla New Member
    VF SS-V Redoine
    The lack of guidelines is disappointing on the vf, I thought that technology was a given for this day and age with all the other kit out the vf has.
    Any chance the guidelines will be added down the track as an update?
  12. The1985divo
    VF Calais V
    Agreed, found the loss of the guidelines a little crazy. miss them a lot
  13. colcha
    colcha New Member
    VF Calais V
    I have the same issue and was told by the service department last week that Holden are still working on a fix for this issue. Has anyone else been told the same thing?
  14. sloys75
    sloys75 New Member
    sydney
    VF SV6 SPORTSWAGON
    Hi there guys,
    i bought a VF SPORTSWAGON where iv got two issues one is when i take off from lets say a set of lights i get like a clunk noise from the rear where holden have changed the tailshaft but the problem is still there its been looked at like 5 times and the other issue is you can hear the petrol splashing inside the fuel tank from inside the car. I was wondering has anyone eles had the same problem its driving me mad
  15. neevo
    neevo Member
    VE Sportwagon SV6
    I've noticed my screen and instrument cluster dims when the auto sidelights come on (eg when going through a tunnel).
    Is this normal? Not sure why it's not set to the same brightness.
    I thought it might be the setting but I cannot adjust the screen etc up when the lights are on
  16. PIR4TE
    PIR4TE Banned
    AWOL with Ari
    Black Pearl
    It's explained in the owners manual, dash lights dim when headlights are activated.
    You can adjust the brightness of the dash lights independently to screen as well under configuration menu -> display -> brightness
  17. neevo
    neevo Member
    VE Sportwagon SV6
    Oops! RTFM eh ;)
    Cheers PIR4TE, will play when I get back in the car.
    I'm normally pretty good at reading the manual, but I find the VF manual a little hard to follow sometimes.
  18. vkcala
    vkcala Member
    VIC
    searching for vk
    I heard the petrol thing in the beginning as well. haven't heard it for a while now
  19. zappaboy
    Mylink is QNX based which 70% of auto audio systems are based. It is the same OS as the latest Blackberry phones use as QNX is owned by RIM (Blackberry) Note QNX is an android and originally was unix based. It has been around for over 20 years and and is a very mature product used in many medical installations, ATM, factory and production systems. I notice from these forums that the latest updates to the Mylink have finally been patched to accommodate the limitations of the IOS so users of iPhones and iPad now have full functionality which usersof Blackberry, windows and most andriod based phones have had since June last year.
  20. PIR4TE
    PIR4TE Banned
    AWOL with Ari
    Black Pearl
    Someone should patch your mouth, stop the dribble :yarr:
