Skylarking
- Feb 3, 2018
- 10,073
- 10,492
- 113
- Age
- 123
- Location
- Downunder
- Commodore Motorsport Edition
Hm, the answer is yes... sad...@RiCeY as a Gold Level Holden Technician, you’d have lots of training/experience and may have a better touch than most occasional home mechanic, But are you saying Holden dealer service departments don’t follow Holden’s own service methods and cut corners? If so, it’s not a comforting thought...
Yes we could always remove unnecessary parts and charge you more labour, good idea.
The attitude in part reminds me of an Air Crash Investigations. An aircraft mechanic used his judgment and years of experience when replacing windscrean bolts rather than use the manual to check the specific part numbers that should be used. The consequence was he saved a little time but installed the wrong bolts and the windscreen soon blew out, partially sucking the pilot out the aircraft. As it turned out the previous mechanic had also installed the wrong bolts but luck was on his side as there was no failure. This time around, the mechanic replaced like for like but he was not so lucky as in this case there was a failure.
And in my specific case, a mechanic replacing an engine pulls bold as part of a Mazda recall didn’t use new high strength air conditioner pull bolts as required by the recall notice but instead used cheap rubbery of the shelf crap bolts. Within a short time, two snapped and one flew off while I was listening to the noise with the bonnet up. Mazda’s solution was for me to drive to the workshop and they’d install the required bolts - they wanted me to drive with one bolt holding on the aircon pulls and didn’t want to truck my car to their dealership. That vehicle never saw a dealer service department again as I bought the full service books for the machine and maintained it at home...
Guess as more and more of the population sees user manuals as a waste of time, that then sets the groundwork for workshop manual service procedures to be ignored and ones judgment inserted in place of the designers and manufacturers of the product. wonder how that will end up in the long term...
Such is life...
Ps: i’d also like to see the latest procedure on how the Cabin Air Filter is installed as defined within Holden’s system. So fess it up
