VF Key Repair
Discussion in 'VF Holden Commodore (2013 - 2017)' started by Fekason, Apr 29, 2015.
  1. Fekason
    Fekason Fekason
    Penrith NSW
    Hi,
    Recently I slipped over in the rain and dropped my key, which someone duly ran over.
    It seemed to work OK, but stopped working very soon thereafter. With a battery change, it works for a short while (i.e. a minute or so), and then stops again.
    I am using my other key, but want to pull the broken one apart to see if a new outer key case ($28.80 on Ebay) would fix things. There is no issue getting at the battery, but further disassembly to get at the PCB and buttons is eluding me. I don't want to get too aggressive with it if I can find the easy way to pull it apart.
    I have searched for help, but only find instructions for the VE, which are not applicable to VF keys.
    Anyone able to help?
  2. vk2him
    vk2him Member
    VF SSV Redline
    Don't risk it - chuck it in the bin - would you like to be 100's of Km from home and find your key doesn't work? Been there, done that, I learned the hard way ..
  3. Wh4l3s
    Wh4l3s Member
    Essendon
    VF Calais V V8
    I agree for the cost of another key just pay for a new one. most likely the internals are broken aswel due to being run over.
  4. matt202
    matt202 New Member
    sydney
    2013 VF SV6 MY14 Commodore
    i broke the flip on mine not too long ago and toke it to Holden and they said it like $415 (for an auto, manual is cheaper because it doesn't have auto start) for the key!!
    luckily enough the second key was already broke when i got the car so Holden toke both the keys and gave me new ones under "warranty" because they were "faulty" when really only 1 was faulty
    Take it to your local dealer and see they might be able to do something for you!
  5. Fekason
    Fekason Fekason
    Penrith NSW
    I expect that most will not have a similar problem, but I went ahead and bought the after market case to give it a try. Sub-$30 beats $400 odd any day.
    Pulling the key that had been run over apart was not easy, maybe because the case had been bent. I basically had to break it up to get it apart.
    Once I had the PCB out, installing it in the new case and reassembly was easy. Works 100% now.
