j_davis_1980
- Mar 31, 2016
- 66
- 34
- 18
- Location
- Melbourne
- Motorsport edition
Higher performance engines like lsa r designed to run at higher compression ratios which equate to much higher temps/pressures in each cylinder : fuels with R.O.N of 98 or higher r designed to operate under these high t/p conditions as the fuel remains stable ( no spontaneous combustion ) so it results in precise timing for optimal combustion : but if u run 91 in these types of engines, the fuel is too unstable in the high t/p conditions present in these types of motors n this can or will cause uneven combustion of air/fuel mixtures resulting in that knocking/pinging noise that u hear : in the long term, continual use of 91 will result in long term engine damage : i wont use 91 in any of my bikes or cars thats for sure ☺
I agree if it's LSA. 91 / e10 should be fine on LS3.
