RACV disagrees with you. (see link:
RACV RoyalAuto - Why high sulfur content in Australian petrol matters–RACV)
P.S I am not saying you are wrong, but there is information out there from reputable sources such as RACV saying that 91 has more sulfur than the premium grade fuels.
Yep know that.
A problem in Australia is fuel quality is not same all around Australia, our fuel is refined, and delivered for all different places, even though their are standards to follow, theirs still some variation to quality we get, and what the fuel company's can do to the fuel, to make there different blends.
Don't have much choice when you only have 5 fuel suppliers, buying for 2 fuel depots, is good reason why I don't see much change between fuel I use, as I all comes from the same boat that docks at harbour, and supplies all the fuel companies, the same fuel.
I just think premium fuel is not worth the money, if economy is only what you look at, but don't get me wrong, if trying, or need peak performance, eg: running at high rpm, towing, hot temps, premium fuels should help the engine preform better, just like good quality oils, do.
It's all matter of trying each fuel type, and see which one you get the best value for money out of.
I've seen many different types engine pulled down after 200 - 500k's, that have run different grades of fuel, very little difference can be see in the engines because of that, more chance of failure because of poor maintenance, like lack of oil, and coolant changes.
Just a point on e10 fuel is, don't use it if your vehicle sits not being used for a month or more, e10 fuel can gum up your fuel system, have seen it gum up fuel pumps, fuel filters stopping cars from running.
