VF SS Series 2 Redline - Brakes
clappa
41
VF SS11 Redline
@clappa, you “have changed brakes on many cars before” but is that pad changes you’ve previously don’t, which is very different to altering brake system by replacing front and rear caliper and master cylinder? Bit more involved in the later as compared to the former.
Like @panhead, I don’t want to offend but it seems your questions are a little basic so I’d also suggest you go speak to a brake specialist. Further, I’d suggest you speak to NSW RMS about your upgrade plans.
Hope your spanner twirling is better than your search ability :p (it’s a joke so please don’t get offended) but there is the infamous @Ron Burgundy Engineering certificate for brake upgrade from SS to Brembo brakes thread that is worth a read and takes you down the brake upgrade rabbit hole. Read it and understand the legalities and engineering of upgrading, then as an adult decide for yourself. There are a few other recent threads also worth a read.
Yep, as per original thread, car already has Brembo brakes, so not upgrading! Maybe my search ability is as good as your ability to read :)
clappa
41
VF SS11 Redline
You have to replace the caliber bolts as they are no reusable as per service manual.
There is a thread somewhere with the part numbers required for front and rear.
Cheers. Thanks.
Skylarking
123
Downunder
Commodore Motorsport Edition
Just to be pedantic, it's "as per original post", not "as per original thread" :rolleyes: :p
But yes, i need to actually read rather than quickly scan what was typed :p
I find google search more efficient at finding stuff than forum search, so try "changing brembo pads justcommodores" in google ;)
First hit with the above was help changing brembo front pads but there are more :eek: you could also search "replacing brake rotors on brembo justcommodore" or similar ;)
And if you've not played with VF's much, probably a good idea to get the workshop manual. You can find a link to it here :rolleyes:
clappa
41
VF SS11 Redline
Yep, already have the workshop manual :)
426Cuda
SUBLIME!
Wagga Wagga
VF Redline Sedan - A6 Spitfire MSE...
With due respect to all and a lot is due. changing pads and rotors is a relatively simple task, for someone with a bit of mechanical nouse. I'm assuming OP has that, as they have already stated...
They're floating, so there's no need for loosening wheel hub bearings.
Other than the obvious jack, stands, spanners/sockets etc, i'd suggest a suitable dia' straight shaft punch to tap the pins in and out and some hi temp brake grease to avoid the dreaded squeal. Also be sure to check the face of the hub and inside the rotor for corrosion or debris to avoid run out issues.
Daniel Souza
46
Glenwood
VF2 Wagon SSV Redline
When I did mine I first tried the Bendix pads without the counter weights and there were no way of getting rid of the squeaking.
After changing it to the new Bendix with the weights the squeaking was gone. I get some from time to time but it is just to remind me I am not having enough fun. So after some late braking the squeak goes away.
