VF SSV Redline and Pixel XL issues with messeges.
HRpuffnstuff
Australia
2013 VF SSV Redline Ute
I am hoping someone else has experienced this as I cant be the only VF S1 driver in Australia with a Pixel XL. I did a search and found nothing.
When I receive a message my MyLink goes bananas spitting out a notification for every message in my phone since the beginning of time (not long ago for the Pixel).
Has anyone experienced this and have a fix?
NewbC4KE
Doncaster, Melbourne
VF SSV M6 & Monaco M4 125cc 2 Stroke Go Kart
Chookah
37
VFII SSV Redline Wagon
S2 Redline with Pixel XL, also having the same problems.
It appears to display notifications for every msg received since the last time you received a msg while in the car.
HRpuffnstuff
Australia
Thanks All. I have reset the MyLink. Problem solved.
HRpuffnstuff
Australia
reset the mylink?
Yes. I had to go through each option and "Factory Default" anything even vaugely related to phone/bluetooth.
Restarted car and reconnected phone, tested with friend sending txt and all OK.
Then I reset all the mylink stuff i missed.
Took about 20mins all up.
Chookah
37
How did you test it, were you already in the car when you received the txt?
I'd like to see what happens if you first receive 2 txt's, then jump in the car and receive a 3rd
VESSVUTE
GC
VF SSV Sportswagon
I have had the same issue. It's really annoying. I am away from my car for a few weeks but will try when I return.
Love the phone but has also been freezing up a bit.
Grant W
VF2 SSV
When using the pixel, do you have choppy Bluetooth streaming? I have the Nexus 6p and is basically not usuable. I don't want to update to pixel if it still has that problem.
HRpuffnstuff
Australia
Streaming music is fine. The screen is slow to register what is playing though.
