Yeah mate, I recognised the fault and suggested it to Holden, there is no problem regarding, strength etc in regards to cutting your screen out, and it should (providing your windscreen tech has some amount of skill) be placed in a correct position with a correct amount of uerathane. If you are going to get it done I suggest a non drive time of 4 hours after it is replaced,(moving around the workshop is okay) mine hasn't made a single bit of noise once, cold hot wet or dry since it got reglued, best of luck, try not to worry too much, it will be fixed.
