VryBigPP
- Oct 22, 2020
- 19
- 17
- 3
- Age
- 22
- Location
- Adelaide, South Australia
- VF SV6 MY14
Hey all,
Last week I had my radiator replaced in what seemed to be a failure of it, which caused a coolant leak and engine overheating. Symptoms then included rapidly fluctuating engine temperatures, a slight leak coming from just behind the oil closer towards the transmission, and what sounded like a boiling/bubbling sound from the coolant reservoir, and what it looked like was that coolant had boiled over the cap as there was moisture all the way up the stick, but no red coolant showing at all.
Fast forward to now, after getting home from a drive I hear what sounds like boiling/bubbling from the coolant reservoir again. I check underneath the car and it's experiencing a slight leak again in the same spot (which had stopped happening when the radiator was replaced). After letting it cool down overnight, I checked the coolant reservoir dipstick and it's sitting on the "minimum" line, which after looking at other threads appears to be expected if it's cold. I haven't experienced any notable temperature fluctuations or anything past what could be considered normal operation, I'm just concerned with another apparent leak that this will quickly become an issue again, and whether it's the radiator or not I've got no clue, but I'd much rather be safe than sorry and catch this out ASAP. After letting the car run for a bit the coolant reaches a bit higher on the dipstick, but nonetheless I'm still concerned about any leak.
I'm unable to see any mechanic until tomorrow at the earliest, so any advice would be much appreciated.
