little hard to explain but pretty much dont touch the 0-25% area that is critical for idle and idle corrections, basically the cnc smooth sections are to be left and the rest can be ground down to smoothly meet up with the rest (dont polish just smooth), the humps can be taken back and i took most out top and bottom so what i done was sit it in zero point pushed back fully closed (use outside of blade points) and mark with pen then using throttle control percentage set it to 25% and marked it with pen (again outside point front side) and took out and smoothed back all areas outside the marked points, do not touch any less then that dont even smooth it off it is super sensitive if u take too much out TB is screwed and i know cos it cost me a TB and the LS2 ones arnt cheap, ill see if i can do some pics and mark out what i done so u can see
