VF Ute towball cover
Discussion in 'VF Holden Commodore (2013 - 2017)' started by LauncestonBloke, Apr 21, 2019.
  1. LauncestonBloke
    LauncestonBloke New Member
    Launceston Tas
    MY16 Redline ute
    Hey guys, just brought my dream ute, a MY16 redline ute! Couldn't happier and loving it apart from some paint that needs some love.
    My only real issue is a purely cosmetic one in that it has a tow bar installed and I'm wanting to remove it and purchase a cover if that's even an option.
    Can provide photos tomorrow if I'm unclear in what I'm talking about, cheers!
  2. stick3
    stick3 Active Member
    newcastle nsw
    vz sedan vs ute gsx1400
    holden or ebay https://www.ebay.com.au/itm/Holden-...632071&hash=item3aeec06825:g:VBMAAOSwsB9bm1Z~
    abuch47 likes this.
  3. LauncestonBloke
    Launceston Tas
    MY16 Redline ute
    Hey mate saw that product, was wanting a cover in the rear bumber for when I remove the tow bar if that makes sense. Wanting a clean ''towbar-less" look. Thanks though!
  4. stick3
    newcastle nsw
    probaly best to get another bar with to cut out still there
    abuch47 likes this.
  5. ChRiDDa
    ChRiDDa Active Member
    N/A
    VE SS-Z Sportwagon
    If you’re going to remove the tow bar completely, you’ll need a new rear diffuser, as when a tow bar is installed, the hole is physically cut out of the existing diffuser
  6. Skylarking
    Skylarking Well-Known Member
    Downunder
    Commodore Motorsport
    +1 what @ChRiDDa said ;) in part o_O
    FYI, it could be worth reading the VF, WN Accessory Installation Manual in PDF format as it specifies what needs to be done to install a 1600kg tow bar to a ute making it easier to reverse the process to uninstall it :)
    You'll find the relevant work description under the following section:
    Code:
        2. Exterior Structural Accessories
            9. Trailer Hitch Draw Bar Package Installation (Ute Tow bar kit 1600kg Inst. 9225316)
        4. Electrical Accessories
            4. Trailer Wiring Harness Package Installation (Fitting Instruction P-N 92270926)
    Do note that when installing the TIM module, Holden program the system. This allows the owner to specify whether the towbar tongue is installed within MyLink, thus avoiding reverse sensors going nuts. Whether you actually want to remove the module or not is obviously up to you.
    But there was a 1200kg tow bar with a flat tongue that was less in your face. Presumably the tongue could be unbolted and thus removed when not in use. I know other manufacturers provided for such on their flat tongue towbars. If Holden also allowed for the flat tonge to be removed, presumably such an arrangement had some cover to clip over the cut out. If such was indeed the case, maybe search for one of those older style bars and a cover as a Ute without a towbar is not quite right in my view :p
  7. Skylarking
    Downunder
    PS: In sedans, a foam crush piece is removed and tossed when installing the towbar. If the ute has the same part (haven't checked) you may also need to source a replacement when removing your bar. The foam is part of the crash protection (at least in sedans) so i'd think you'd want to preserve such engineering if that part is also used in your ute. .
    saroadie likes this.
  8. Philmecrackun
    Philmecrackun Active Member
    Lismore
    VFII Calais V 6.2L 1972 Ford Galaxie Wagon 400ci
    I'd leave it in, a bit of more protection when some rear ends you, at least they are going to get some serious front end damage. You could then trim it up with a protector from Hayman Reece
  9. lordsnipe
    lordsnipe Member
    VF2 SSV
  10. Blue.Goose
    Blue.Goose New Member
    VF Commodore Ute Black Edition
    A dated post and you may have already come up with another option; however, someone else may be interested.
    Made up from a chrome finished hitch cover that I purchased from SuperCheap; a piece of waterproof yellow background reflective tape (which I had laying around) and a "Holden HSV Lion Rear Trunk Badge 69mm Silver/Chrome" badge purchased from Ebay.
    I had to drill new holes in the hitch cover so that I could fit the locking device though.
    abuch47 likes this.
  11. abuch47
    abuch47 Active Member
    Madelaide
    LSS3 YOOTE
    belongs in an art gallery not hanging off the back of some commo.
  12. LauncestonBloke
    Launceston Tas
    MY16 Redline ute
    i love it Blue.Goose, thats a genuine talent you have there mate.
    personally i have no need to tow at all and as a result im after a more clean look.
    This little insert is what i'm after but it appears very hard to find!
  13. lmoengnr
    lmoengnr Well-Known Member
    Sunbury Vic.
    MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
    Its not actually an insert, its a cut line.
