What is "optimum" really?
We'll start at the exhaust manifold outlet of 2 1/8" a reasonable size outlet for a stock carburettor 308. The manifold outlet on a Chrysler 6.4 litre (similar size) SRT engine is 2 3/4". Holden fits a 2 1/4" V6 midpipe and muffler assembly to the LS3 buts drops to 2" over the trans tunnel brace and discolours from mass heat build up. Then the inside diameter of flexible bellow at the rear muffler flange reduces down to 1 7/8". Who ever signed off on that for a 6.2 litre 300+ kw V8 exhaust needs the sack! Alternatively, they could have fitted the R8/LSA 2.5" midpipe with the X-pipe and 2 hot dogs and saved on the V6 muffler assembly. Chrysler ran a twin 2.75" exhaust on their SRT engines far more optimally sized for a 6.4 litre Hemi.
We get to the bimodals and that's a joke seriously, here's the inside.
The Bimodal inlet is 2.25" with a 3" section of perforated tube fibreglass packed in the front chamber. From there to the outlet it's straight pipe, so a third of the muffler is used for sound control and that's why the bimodals have a lousy note with the valve open. With the valve closed, the exhaust gas has to pass through the perforated tube and the fibreglass packing to reach a few holes in the front chamber plate. With the valve closed, you may as well shove a bit of rag up the exhaust pipe and block it up creating mass back pressure. Again, I'd sack the designer of that abortion too!
What they should've done, is have the perforated tube end at the front chamber plate, leave an open centre chamber and the rear chamber instead of straight pipe, should've been perforated tube and fibreglass packed and that's a Lukey design and sounds magic and flows well enough with the valve closed. Holden could have done exactly that an no extra cost if sensibility prevailed. Instead, they mess around with that silly bit of tube off the airbox to the firewall for a fake intake roar and cut holes in the exhaust tip to leak noise under the rear bumper. That's supposed to impress enthusiasts the V8 Commodore targets, they're off their chops!
