if u run e85 in a boosted stock bottom end it will last longer as it absorbs more heat out of the combustion chamber once ignited so its better for a stock cast piston, but it also adds more torque so u do get more load on the components, flex is good i have converted mine to flex so can run what ever i want and if i go on a long cruise just use petrol, if the sensor fails u can set it up in the tune so it defaults to a set ethanol % so u can make that safe for a failure, when i changed to ethanol with no tune changes to timing i gained bout 70rhp
